EP. 33: Big Ol' Serving Tray
Thanksgiving is right around the corner - how are you going to serve the bird? Presentation is everything so Morgan whipped up this big ol’ tray for the occasion. It was originally designed as a quick 2D project, but to give this tray its 1" radius deep into the bottom corners, no bit was available.
Rather than compromise on the design, he toolpathed it as a 3D carve. When you don’t have a bit(s) for the task at hand, think outside the box! With just a bit of creative toolpathing, the Onefinity can handle just about anything you throw at it.
Download the vector and cut files here…
Big Ol’ Platter Design Files.zip (5.6 MB)
Also, did you know Onefinity has a podcast!!! Check out The Cutting Edge Podcast here…
If you’re in the market for CNC bits, get 20% off your entire order from Bits & Bits with the promo code 1FCuttingEdge at checkout!
Love the tray, but having difficulty in getting the 3D file to convert to mm. I usually just get the profile cut and lose all the 3D carves. Tried several way to import, scale, etc… No luck. Any chance there be a mm version of the file?
Caesar
Alberta
Canada
Can this be purchased as a finished product directly?
I’ve had the same problem going from a metric scaled model to imperial using vcarve. Easiest way is to import it as imperial in this case and then change to metric after the model is set.
Can I ask something?
You dont have to ask if you can ask, you just ask.
