Error: Y axis position -0.254mm is less than minimum soft limit
I’m setting up my Journeyman and have not cut anything yet. I’m trying to lightly score the tabletop using the CNC so I can align my spoilboard planks. When I run the file I created in Carvo, I get the error,
“Y axis position -0.254mm is less than minimum soft limit 0mm while executing code…”
To get to this error, I homed, set Z using block, and loaded the gcode. When I run the code, I get the error. It’s as if my home position is too far to the left?
To create the file, I just made a 48.25 x 32.25 rectangle and made a profile toolpath set to cut at 0.01 depth. Do I need to make it less than the maximum cutting area to fix this?
Here’s what I found that helped.
