Feed rate override
a way to go above 200% feedrate override so that you dont have to reprogram if you were too conservative
I believe you will find the maximum feed rate override options to be 150-200% in most hobby and industrial CNCs. While I understand the value of this feature and use it regularly when testing new toolpaths, I feel anything above 200% should have me spending more time researching my job and CAM parameters.
I have to agree with Tom here. 200% is a lot - we’re talking 100 to 200 or worse, 200 to 400.
Perhaps if you set 40ipm and should be using 100ipm, OK, but again, that’s probably a different problem.
