I k ow this has probably been asked a hundred times. I’m running build botics and it seams that the top feed speed is locked at
80 ipm. I have tools that can run at a higher speed, but the controller plugs in 80 ipm.
Is there sa setting I change so I can run a higher speed?
That is controller by your cad. Top speed in the controller in x and y is 398, not 80.
Ok. I’ll check it out.
