First successful indexed 4axis project
Not much to say other than it took me a really long time do dial in the rotary and write the CAD and CAM.
The outcome is pretty stunning though.
This is a four sided cut with automatic rotation. There is only one manual tool change.
Software: Deskproto
Roughing 1/4 end mill, doc 2mm step over 2mm, speed 10000mm/min.
Yes, the 1F is screaming, so roughing takes about 30 minutes.
Finish with a R 0.5mm tapered ball end step over 0.1mm feed rate 10000mm/min which might be a little on the high side.
Takes about 4 hours to finish.
Nice! DeskProto is great for rotary stuff.
Which method are you using to set the zero point for the rotary axis? That’s the tricky part, since being off by a fraction of a mm really stands out on indexed rotary jobs.
I had a 1/4 inch rod in the spindle and used the touch probe. The chuck is precisely 100mm in diameter.
I use the G59 coordinate system for the rotary.
I modified the Deskproto post processor so that it will use the g59 command at the beginning of each cut which was quite easy.
I rarely measured X, Y and Z0. The Masso just remembers the work home. Of course this only works with the tool setter.
I remember that was a nightmare with the buildbotics controller.
My rotary is permanently installed just off the waste board, only the chuck is inside.
Cracking job.
I’ve had one go at 4th-axis indexed milling. It’s tricky to find the centre, and I was still off by a tiny fraction in my attempt.
I had two 1/4 inch rods, one in the spindle and the other in the chuck, but I still had to “manually adjust” the calculated values to cut a cube from four sides. I roughed with a 1/8th bit.
What was your method for "dialling in " the centre?
FYI: I used f360, which wasn’t too tricky. Using previous set-up stock and duplicating setups for the other sides was relatively easy, contrary to my expectations, and meant that I limited the re-cutting of previously cut areas.
I had a long rod in the chuck when I installed the rotary on the waste board to have it point in the right direction parallel to the y axis.
I think there best way to center is to use a rod in the spindle and touch of with the masso probe cycle on the chuck. Yes, you can also put a rod in the chuck.
The rotary is attached and has to be only probed once, and the coordinates should be in the masso forever.
The live end is far more difficult to center. I have to readjust and check it every time I move it. I use the rod in the spindle and micro adjust the tailstock.
Yes, Fusion should be great for this too.
I am still curious about their pricing, do you have the free version, and is that limited or the subscription and how much is that per month?
I have the free version of F360.
It is restricted. The biggest restriction, for me, is the lack of rapids at rapid speed. They are throttled back to, I think, the last feed rate. It is a problem with large jobs that have fine detail spread over the job (e.g. rest machining).
For rotary milling i use vcarve.
Interesting. I remember researching this a while back and concluded from others attempts that it was too tricky. The f360 add-on you have identified above looks more promising, but it still claims to be experimental. I will give it a go. Thank you for the post
Finding true center of 4th axis is really simple and easy, I do mine with an indicator, sweep centerline with indicator to get close on your 1/4 rod, then to fine tune it, position 4th at A0. And indicate one side of centerline then raise up in z and rotate indicator to opposing side and then rotate A axis 180 deg and sweep that side. Split the diff in axis. Should be in within .0001 or .0002” from centerline. Thats how I have done it for over 30 years. But that is true center of rotation.
I for got to mention, that when you rotate 180 deg, you need to lower z back to same z you had before, that is really important.
Wow. I think that is a spectacular result. Well done on the programming.
Beautiful!
I recently got my rotary and installed it on my Foreman Elite. I had a significant issue with a homing error initially, but tech support helped me resolve it. I’m using DeskProto, and have my first carve all set to go. But every time I home the machine and probe the X, Y, and Z, and start the carve, the single soins up, waits for about 10 seconds, and then moves to the left, instead of to the right, and the block. I have been struggling with this for twelve hours, and have searched and tried every setting I can find in the program with no luck. I have attempted this carve at least thirty times! DeskProto tech support is on vacation until the 26th, and the minute I say anything about DeskProto to Onefinity tech support, they shut down, say they don’t support it, and refuse any help at all! This pisses me off, because I’ve spent over ten grand with them. If I thought for a minute that they would only provide support for their machines while I’m using one of only two or three CAD/CAM programs, I’d have run away to another brand!
Which machine selection and post-processor are you using with DeskProto? I bought the multi-axis license.
Did you use Aspire or Vcarve pro to make your model?
Because there is a sneaky flip model button that is always checked off in the software which is easy to miss in the setup.
No, I used DeskProto. When I run a carve animation in the software, everything is fine. When I run the carve in the rotary, the cutter moves away from the piece, instead of toward it. It has to be a setting somewhere, but I just can’t find it.
So when I initially used my rotary It did the same thing. It turns out I needed to update to a rotary post processor. In my case a Y wrapped Masso processor.
The regular post processor assumes Y direction is a linear movement whereas in a rotary Y is rotated when using the rotary hence the need for a different post processor.
Did you ever get this resolved?
