New Elite foreman owner, just got everything together and have an issue with flattening the waste board that likely is an issue that I am doing but cant seem to see my mistake.
Elite Foreman, on a QCW / Leg set and while the qcw is fasten from above, I removed the threaded press fit pieces and countersunk /wingnuts the boards to mount, the head of the screws are .4" below the surface.
Prncnc, 2.2kw water cooled, square to the bed
3/4" mdf installed, initially had back to front .025" high at the back, used shim stock and got front to back to <.010"
Set the Z zero at the high spot, set final depth of cut at .020"
VCarve pro, made a flattening file as above, spetools 2.5" flattening bit, 50% stepover
started the operation and every pass from front to back is slightly deeper than the previous pass
actual depth (lip to bottom of cut ) was .0105" as roughly expected (back +.010 high, zeroed, .020 depth so front starting point was -.010 neighborhood
The Z on the display stayed at the negative value that it started, but by about the 10th pass the depth of cut from the lip was .153! at this point it was hogging too much wood, and the spindle stopped.
Z still stated -.020" ! For the life of me I cant see where the depth is coming from. I’ll measure the bit in the spindle, but I had it really tight but I forgot to measure it.
Any thoughts on what I might be screwing up? Shut and down and walked away for the night…
Any pointers are appreciated.
