I have been working around the machine. Not using it. When I try to home it the X axis only will move a little from the center. If I run it to the right side and then home the machine the X axis will go to zero and then give an error. I have set the X to zero but it still does not home. Can anyone help? or at least point the way.
Well, it isn’t the light. When I tried to use the probe the Z was right, as was the X but the Y axis moved away from the plate. So it is backwards. I have not changed anything since it worked before.
