Getting laser to turn off when moving from cut to cut
Does anyone know how to make the Jtech laser turn off when moving from one burn to the next. I watched a video addressing and it talked about turning laser mode on with a button or g-code command but I am using the vetric laser software and can not figure out how to do it.
I cant directly help, but you may want to confirm that you are using their add-on laser module.
I appreciate the support David. As it turns out the controller for the laser was faulty and upon receiving the new one everything is now working fine. Thanks.
