Great results with Single Flute Bits on 1F with Makita Router
Thought I would pass on my latest discovery that has improved my cnc experience. Bottom Line Up Front: single flute bits seem to be a good match for lower power hobby cnc machines… they enable you to run at lower feed rates while maintaining a decent chip load.
I’m not sure why 1F doesn’t offer single flute bits for sale in their online shop… If there is a downside, I haven’t found it yet.
If any of you more experienced 1F cnc’ers have experience using single flute bits, I am interested in hearing about it… particularly if there is something that you do not like about them.
Hope this info helps someone out there!
Makes sense. What diameter bit are you using?
I purchased a dozen cheap Chinese bits… 6mm, 4mm, and 3.175mm to give them a try. They are tungsten carbide and that one cutting edge is razor sharp (I actually sliced my finger when I carelessly removed the bit from the packaging). I noticed that Amana and Datron have them if you prefer US made bits… I have not been able to find a cheap round nose single flute… so I’ll probably be purchasing a Datron soon.
Yea… I ran across an article that recommended them for hobby level machines… and that was the best tip I’ve had… I have found that the makita router does a much better job pulling the one super sharp flute through the wood with much less vibration and noise than any of the two or three flutes bits that I have.
THis is a great tip! I am going to order a few and see how it goes. Do you have any advice on feeds and speeds to share?
Bern,
Sure… I try to stay close to the feed rate from this simple formula:
Feed rate = Router RPM x Chip Load x Number of Flutes
…for the hardwood that I am cutting, I am running the Makita router at approximately 10000 rpm which is about 1.5 on the speed dial. A reasonable chip load for hardwood is .008" to .01"… which gives:
Feed rate = 10000 x .008 x 1 = 80ipm
to
Feed rate = 10000 x .01 x 1 = 100ipm
… and even if you drop a little below that… say 60ipm, you are not rubbing and burning up your single flute bit.
The obvious outcome from the formula is that with a 2 flute bit, you are up to 160ipm to 200ipm to get the same chip load… and if you slow it down too much… say 60ish or below, you get a chip load that is less than .003" which starts to put you in a zone where you may rub and heat up your bits (which is what I have done). Of course 3 flute bits are even worse.
