Has anyone tried the redline controller with code from easel
I have included sample code from easel pro.
Redline.nc (138.6 KB)
If someone had this working we would have a post by now. The BB controller should be supported until redline is stable. If this was truly in devlopment five years where is the testing. Looks like this started soon as masso became a problem by building pay walls. Fusion 360, Easel, LightBurn, and vcarve support are a must. Is this thing getting a ip address on wifi and ethernet? Do we have sample Laser work?
I have used the code from easel cabinet maker for drawer boxes and it worked good without issues.
It does get an IP from WiFi or Ethernet cable which allows you to remotely add files and watch usb camera and status
I’ve used my jtech a lot with the redline using both lightburn and vcarve laser module without any issues as well
Thanks sounds like it is shop ready now.
I was batch one and haven’t really had any issues with it all. Only thing I had a small
Issue with was the bit setter. But just sat it aside and going to install when I get aTc. I’ve use vcarve pro primarily but have used easel cabinet maker, carveco, lightburn, and fusion
