How to move to specific coordinate via gcode
To move to specific locations using MDI (Manual Data Input) and G-code, you’ll need a CNC (Computer Numerical Control) machine, such as a milling machine or a 3D printer. G-code is a language used to control the movements of the machine. MDI allows you to manually input commands directly to the machine’s controller, which is useful for making quick adjustments or performing specific movements without creating a full G-code program.
Here’s a general overview of the process:
  1. Understand G-code basics: G-code commands consist of letters and numbers that represent specific actions, such as movements, tool changes, and more. Each CNC machine has its own set of G-code commands, so you’ll need to refer to the machine’s manual or documentation to know which commands are supported.
  2. Home the machine: Before moving to specific locations, it’s essential to home the machine. This process ensures that the machine knows its starting position and establishes a reference point. Depending on your CNC machine, there might be a specific G-code command for homing (e.g., G28).
  3. Open MDI interface: Most CNC machines have an MDI interface where you can directly input G-code commands. Access the MDI screen on your machine’s control panel or software.
  4. Input G-code commands: In the MDI interface, you can manually enter G-code commands to move the machine to specific locations. For example:
  • G0 X10 Y20 Z5: This command moves the machine to the point (X=10, Y=20, Z=5) at the rapid speed.
  • G1 X30 Y15 Z2 F100: This command moves the machine to the point (X=30, Y=15, Z=2) at a feed rate of 100 units per minute.Note: Be cautious when using MDI, as there is no verification step. If you input incorrect commands, the machine may move unexpectedly, potentially causing damage or injury.
  1. Executing commands: After entering the G-code command, execute it through the MDI interface. The machine will then start moving to the specified location based on the command you provided.
  2. Check the position: Once the machine reaches the desired location, you can check the actual position using the machine’s control panel or software.
Remember, G-code and MDI are powerful tools that require understanding and caution. Always be sure to familiarize yourself with the specific G-code commands supported by your CNC machine and take appropriate safety measures when operating the machine. If you are new to CNC machining, consider seeking guidance from experienced users or professionals to ensure safe and efficient operation.
