You want to have the power cord from the VFD U,V,W going to the spindle and have it shielded. You can purchase shielded wire or use SJ cord and add a outside copper tinned braid that is grounded. This only has to be attached to ground on one side of the wire cable or braided sleeve. That is how I am running mine with no problems. The spindle is rated at 10amps by HuanYang. so you will want to make sure you have at least a dedicated circuit for optimum performance. I set up a 20amp (12ga nmb wire) circuit from the fuse panel to the VFD box but added a 35amp 220v rated on/off switch before it as shown in previous replies. I used 6-20R and 6-20P plugs with 14ga. wire to the vfd which is rated for 15amp.
Wayne
(Wayne)
21
Related topics
| Topic | Replies | Views | Activity | |
| What is needed to wire up 2.2kw 220v Spindle and VFD? | 26 | 15357 | September 8, 2022 | |
| Huanyang VFD and Pump Wiring Diagram Review | 2 | 2852 | January 22, 2024 | |
| Speed control dial does nothing on VFD (SOLVED) & VFD wiring | 39 | 6452 | May 4, 2022 | |
| Proper Grounding; How have you grounded your frame? | 24 | 8871 | August 25, 2026 | |
| 220 volt huanyang vfd | 13 | 4702 | January 17, 2022 |
