I did not cut out far enough solution
A newbie mistake of course I had everything set up on the previous carve but then i grabbed another piece of wood and ooops it was thicker. I have done it before with more or less square objects and used my bandsaw to cut it free and then sand it out, but this was a heart shaped carve and I did not want to screw this one up as well (previous carve forgot to z zero.) so I thought for a bit and ended up running it upside down through the planer that has a spiral cutterhead. I ran it a few thou at a time and bingo I was able to get it paper thin so I could break it out and easily sand off the tiny bit it hung on by. It is not something i recommend doing all the time, but it did save my carve.
…in a similar bind, but without the planner option, I flipped the piece and surfaced the backside until thin enought to break free.
that was not an option on a heart shaped object there would have been nowhere to use clamps and I did not want to make the front surface all sticky with double sided tape.
A jigsaw and a flush-trim bit come in handy during times like these.
These are great solutions! I too shared similar experiences in the beginnig. A lesson I learned early on was to delete my gcode after each use. This forces me to reset the job parameters for each carve, which forces me to grab my calipers.
This how I do many of my projects
Cut down from top surface and leave approximately 1/16 inch holding at bottom
Band saw and clean up with flush cut on router table
Homer 57
