I'm in! Just made my order
Found out about the current promo the day after Christmas, and after a week of hand-wringing, I just pulled the trigger.
Order #54XXX so I’m well into the last date range listed on the shipping page, March 16+. And probably later as I’m a few hundred orders AFTER the beginning of that range. But hey, good for them.
I’m already drawing up my table/enclosure, and have dust collection, other benches, tools, etc.
Besides bits, is there anything else I need to source in the meantime so when it does arrive I can get started right away?
See y’all in the spring I guess.
Congratulations! I am in the same batch and can’t wait for mid-March.
From what I’ve seen in other posts and YouTube videos, make sure you have a dedicated circuit for the controller. If you selected the 2.2kw spindle, you would also need a 220v outlet.
I went with the 100v spindle purely because 220 would involve upgrading the entire outbuilding it will live in, so that’s out for now.
Currently I have a branch unused that the machine will occupy but I will be adding another as it is advvised to have the VFD on a separate circuit than the spindle.
Lord knows I’ve got the time to get it done before arrival.
I’m telling myself first week of April so I can have a happy surprise if they beat that.
My two cent, Make sure you can get around all of your table if you got the big 48 by 48 version. My set up
All good here. 32x40 shop and I’ve been rearranging this past week to dedicate space for the 66"x66" table I’ll build in the next few weekends.
Putting the dedicated circuits on ceiling drops since it won’t be up against a wall on any side and I dont want cords on the ground.
Great you will love it. One thing I just added is a MPG and you might want to consider after you get set up. A good dust collector that is also not too noisy ( Like what your spindle will be …very quiet) I think is important I install the festool
Just so good…
I love the excitement.
So many things to cover:
1 - software - CAD and CAM. Get what makes sense for your skill level and desired outcome. My recommendation - DO NOT buy something expensive to start. Start with the free options and work up to the more complicated software.
2 - bits - 1/4" flat end mill, 2 flute – up and down cut. These will be your go to. Don’t buy anything else until you need to. Probably a 1/8" end mill or a v-cutter or maybe a ball end mill. You won’t need anything else unless you do something specialized.
3 - You will need a table and waste board. Tons of options here. Just make something rock solid for the base and something easy to replace for the top. You will thank me :wink:
4 - shameless self promotion - Digital Manufacturing 101 – designed to give the new user the whole end to end look and avoid common mistakes.
5 - when you are ready: Making Cool Sh*t
Happy to answer any questions. Welcome to the ‘club’.
Thanks, Tom.
  1. I’m already at least a beginner in CAD/CAM, I use conFusion360 and OnShape for 3D printing, as well as G-code for the 3D printer as well as my laser engraver. The machine comes with that first year of carveco but i wont activate that til I at least can anticipate a delivery date. Ive already been messing with a trial of Vcarve and have a hunch I would be OK with paying for it.
  2. I’ve got 1/4" up/down/compression bits, 1/8" downcut spiral, a surfacing bit, and a bunch of other router bits that have no business in that spindle. So other than maybe a V bit it sounds like I’m good there until, like you said, there is some specific need. By now I know better than to buy anything besides socks in a ‘set’.
  3. The table is in the layout phase presently and sbould be built weekend after next. I just built a new lumber rack for full sheets and will stock it with some MDF on my next trip to the plywood supplier for some 3/4 ply for the table top below the wasteboard and eventual enclosure.
So it looks like for now all I need to worry about is #4 and #5 :wink::wink:
Cool. MDF is the best top for the table – easy to get, easy to mill, it’s just super messy when you surface it.
