Is your router frame a parallelogram? Mine was!
I am not an engineer, but I feel the strength and stability of the dual steel shafts and mounting blocks would negate any negative effects of a warped screw. If the shafts bowed out slightly, that might explain what you are seeing, but I think the odds of them being bowed in such a way are very slim.
I tend to agree. As noted, the apparent bowing is the x-axis direction as is the 1 mm inaccuracy. Will update with more test cuts once it’s been re-mounted.
Hey woodsnipper,
From a distance, it is difficult to say what is the exact cause of your symptoms. There are many starting points on such a system to try to identify errors. But excluding sources of errors is always a good starting point. As such, beginning with a perfectly flat table is what I would do first.
Do you have a 3D printer?
Unfortunately not. Was eyeing that mounting bracket template. Wondering if I can print it on paper with any accuracy…
The thing with them is that they offer alternative temporary mounting holes of good accessibility and visibility, ideal for marking and thus squaring in the next step, but they achieve this by the four small cylinders gripping precisely into the screw holes of the feet. Difficult with printed on paper.
Another possibility to fix the feet sort of precisely is to use bolts with the exact diameter of the holes in the feet, and also drilling the holes in the tabletop with the exact diameter.
But before this, to find the right positions of the screw holes to drill, I would not refer to dimensions in the documentation. I imagine that every machine could have slight differences in positioning of the feet. Therefore I would see it as a necessity to record the exact dimensions (i.e. exact distances betwen the positions of the holes in the feet) for every individual machine, either by measuring (difficult) or by marking them (easier) on a surface. The difficulty here, as John stated, is on how to mark through the deep screw holes in the feet accurately. Here Tom’s 3D printed mounts are of unvaluable help.
Also the feet should be checked for twist.
@woodsnipper
Okay this is bit rambley but I fell your pain and frustration as I was there. So I want to help as much as I can.
  1. You probably need a bigger square a speed to really check. I used a framing square like this ( Empire 16 in. x 24 in. Laser Etched Framing Square-1190 - The Home Depot). I also purchased a long metric ruler from Mcmaster. I found it practical to have the measurements on the same side. Certified Lightweight Aluminum Ruler, 2 M Long, Right to Left, mm and cm Graduation Marks | McMaster-Carr (Some might feel this was overkill thought :man_shrugging:t3:)
  2. If you wanted I could probably print the mounts for you, I would just like to be reimbursed for shipping cost and plastic. Assuming @TMToronto doesn’t have any objections.
  3. @349iq2345 is right check for the twist too.
  4. For marking the center of the holes, after squaring it up as much as you can by measuring, I used the biggest brad point bit that would fit in the four holes at each feat, taped it lightly with mallet to create a starting point. Than used a long bit slightly smaller than the threads of of my pocket hole screw to start the hole. You only need to go down a 1/8 to 1/4". This will give you some play if you need to adjust your feet.
  5. Also I don’t remember who recommended it but securing it down with pocket hole type screws (the wider head version) and 10-32 washer is much easier and will give you play if you need to adjust. (Pretty sure it was 10-32 :thinking:)
  6. If you would like, I could try to write out the procedure I used to square up my frames.
No objections at all - happy people can get use from the template.
@TheyCallMeJohn thanks for the help, a procedure is exactly what I’m looking for. I really don’t want to go from ground up a third time!
The brad point is in line with my thinking (a center punch is too thin or likely to jam in the mount hole).
I’m certainly not afraid of buying more measuring tools, though I still have dreams of making some measuring devices using the CNC if I can get it accurate enough.
Other than following the setup video I’m not entirely sure of the sequence of events to get it all lined up. I’m willing to photo-document the process if you can lay it out textually. A how to guide for future users. Would take you up on the template if that is the way to make it work. :slightly_smiling_face:
Really appreciating the forum here!
I’ve been following this thread as I want the machine as square as possible. I want to do inlays eventually and I think square will be pretty important. 3 things I found going through every squaring procedure I could find …
  • my left and right Y rails do not travel the same distance. When I adjusted the setting for travel / rev you can only set for 1 motor - the slave is not settable. I set the left one as accurately as possible and will have to live with issues on the right side
  • I found that when you home the machine it does not always home in the same place. I hit the home button for each individual axis several times until there is some consistency in the position measurements.
  • I found that there is a little wiggle room at the connection between X and Y rails. I loosened the bolts and pushed one side back and the other forward for that final little adjustment.
@rccoffin Good points, never considered play in the x-rail mounts or the distance setting.
I thought the homing wouldn’t be a problem as you zero the workpiece. I picture home is just a way to avoid exceeding the rail limits.
One other thought on measuring (inside diagonals at least) is to use this: Wood Folding Rule, Inside Reading - 900-6 | Klein Tools - For Professionals since 1857
I wouldn’t necessarily rely on it for the distance, but it’s good for transferring measures for one side to the other.
I found one of my self centering bits for hinges fit in the foot perfectly and allowed me to drill a 1/8" pilot hole with it. FWIW I put threaded inserts in the table under my feet and used 1/4x20 screws to secure them.
I actually just finished realigning my 1F (after an unfortunate crash caused by not having the bit collet tight enough) and rechecked all the alignments. Yup, mine was no where near x/y square and it took me a good hour to tune it in to within a couple thousandths again. Whew!
In the next table iteration I intend to devise a means to micro adjust the squareness as well as fine tune the vertical axis’ as well. I’m not sure how that will look yet so…film at 11.
If successful I’ll post here about it, of course.
Update on my parallelogram situation. Did the following:
  1. Took everything apart
  2. Added another board on top of my existing table to achieve a surface as flat as possible
  • For me this was with 1 mm in each direction using a flat edge; side to side, front to back, and diagonals.
  • I used used jack hand plane to flatten the board underneath, then glued a 5/8" melamine 4’x4’ piece on top with construction adhesive.
  1. Followed the Onefinity assembly video with these additions:
  • Used a center punch (wrapped it in a few layers of hockey tape to get it just the right size for the mount hole) to mark each hole. This worked surprisingly well at getting dead center.
  • Pre-drilled each mounting hole using a 8" long 1/8" drill bit per forum.
  • Used #9x2" GRK screws (R4™ Multi-Purpose Screw | GRK Fasteners) with #10 washers to mount. These allowed for a bit of play for adjustment, but easy to use and stable.
  • Compulsively checked the diagonal distances and for square against the known straight bottom each of the mounting board. Moved the gantry back and forth several times while checking.
  • Mounted front corners as per video with gantry in front, then all back mounts with gantry at the back (4 on each), then the rest of the front mounts.
  • Check distances and square again (then once more).
  1. With everything seemingly accurate (and connectors etc. attached), used the game controller to mark each corner as per this: https://www.youtube.com/watch?v=lU0iZKajpoo
  • Those measurements were as perfect as I was able to measure: 81.5 cm on edges and 115.4 cm diagonals.
Discoveries:
Conclusions:
  • Having a moonscape tabletop may not be sufficient for mounting the Onefinity.
  • Check your rails for twist (can’t do this with a flat top for reference)
  • Check your measuring tools for accuracy!
With thanks to those with constructive comments and kind offer to supply the mounting template @349iq2345, @TheyCallMeJohn, @TMToronto
Like @woodsnipper said check your squares for squares. I was confused the other day when after I squared up my machine it seemed more out of square. Turns out the large framing square was noticeable out of square.
If you are using a framing square I would check out this video.
Also if your machine is just a little out of square and you are using the coupler nut method to protect your bearings, adding a washer (or two :woozy_face:) can help bring it in. You can do less with a few layers of soda can. It is pain for me to unbolt everything because I essentially have to remove all the cable rails just to do a minor adjustment.
Lastly if you end up having trust issues with your square like I did. You can use this method to bring it into square. Note this only works with the coupler nuts at the rails.
  1. Get it as square as possible with the above methods.
  2. Set 0,0 to the center of your machine.
  3. Have your machine engrave a large rectangle with a V-bit about .30 mm deep.
  4. Mark the corners. (I found putting a push pin half way in at he back and sewing pin at the front helpful.
  5. Measure the distance between cross pins. The delta is approximately is how much one side needs to be shimmed out. I.e. if 3328 and 3330 mm. I would add two .
  6. Rehome y and set your zero to the precision offset
  7. shift your zero by 5 mm or so in the X or y.
  8. Repeat steps 3 thru 6 until you are happy with the result.
I haven’t read the entire thread but this is how I squared my machine.
First, get the sides parallel.
Then check corner to corner.
That is pretty cool tool.
Thanks! It is just a dial caliper on a magnetic base stuck to a piece of steel stock.
I was lucky and found a Starrett at a garage sale but I just saw a magnetic base at HF for $12. They probably have a caliper as well.
What a great system. One thing I am curious about. I noticed on mine a small bit of ‘play’ possible because of the two pairs of set screws that hold the Y tubes in the blocks - not much however. So theoretically if you loosened them all and pushed one set of Y blocks together, and pulled the other set apart, then retightened, I am guessing there may be a few mm difference in length. That could impact the squaring, but a small amount at best. I would be curious how close they are. Would you be willing to use your measuring system to see if there is variation in distance between your Y axis blocks (those connected to the same two tubes). I checked mine and they were the same (but I only have a standard tape measure, so by eye they looked to be the same distance apart).
I would be glad to. I am going out there today. I’ll post the results later.
EDIT: I checked. There was 7 thou distance (.007) difference between the Y blocks on my Woodworker.
I am glad it isn’t off by too much. I have everything built!!! I am also glad I didn’t think of this before I started building because I would have driven myself insane trying to remedy those 7 thousanths! :grinning:
