J-Tech laser fires when reset button pressed
Looking thru the forum I don’t see this problem addressed.
Just connected my J-Tech 14 watt and when I pressed the reset button it fires the laser. I double check the connections and jumpers and it still fires regardless of J3 or Tool setting to VFD or laser. Obviously, something is enabling the laser from the controller but what?
Found the problem, for anyone stumbling across this.
The J3 jumper is actually not accessible unless you take off the cover. What I thought was J3 was J2. Moved the jumper and now functioning properly.
