Has anyone installed the J Tech Spindle Mounted Laser on their Onefinity?
Why would you want to do that? It is more expensive then the one designed for the 1F with the same power.
Would get to use the full 32.125x32.125 cutting area and also not have to deal with the offset when using laser and router on the same project. But you’re right the benefits probably don’t justify the cost.
Ooof, Look’s like it would rotate too…
Not having to deal with offset is pretty appealing. Plus this type of mounting is more universal so it could be used with another CNC easily.
