Jtech Laser accessories
Hello,
I have the 64W Laser accessory, and with it came all the mounting hardware. However, there are 5 little 3d printed blocks with a screwhole tab on them. I assume they are for the little sticky sqaures for routing cables and such. Is that the correct assumption? I’m guessing they are used as the little sticky squares have limited purchase on the CNC frame itself. Is there a suggested mounting place for these?
I’ve found nothing in any of the manuals, videos, etc. So any suggestions would be helpful.
Thanks.
Well disregard. I was doing a little clean up and I found a folded peice of paper tucked into one of the boxes that everything shipped in. It indicated what these are, material risers. So you set the material you’re cutting with the laser onto these. It was a black and white printout, and I almost missed it. It’s also a bit funny that I just happened to find it after posting this.
I’m glad I didnt go on my hunch for this, lol. I have also been wondering what I was going to use under the material on the CNC table when I use the laser, here’s my answer.
I’ll leave my post up in case anyone ever wonders the same thing.
