Jtech laser offset
Does anyone know the laser offset?
Thank you,
B
I actually measured the offset. But I guess it will only work for me. Anyhow here is what I found : deltaX = -1.5mm and deltaY = -79.5mm
mine was -.05 in x, and - 2.75 in for y
Layne mims
How do we find the offset, please
Hi Gregory,
Basically when you laser is attached, you home your machine and then you fire the laser. Second you move your router to the laser spot left and look on the screen the displacement.
Hope it helps.
B.
how do you accommodate for the offset in you g code? 0 X and y then set the offset as your 0? this off set should be relatively consistent due to the mounts being the same? or is that taken into account when using the laser module in Vectric program.
What Bcadet said was perfect. I made a video showing how to do this before seeing his solution. Here’s a video I made where I went through the process: How to find the exact offset of your J-Tech laser on your CNC machine - Easy! - YouTube
Thanks for the video. It there a way to save the laser zero?
Bumping this. Kudos to @Bcadet and @GoodTimberDesign
After establishing the offset, what’s the easiest way to account for this? I suppose I can simply use the joypad to the correct offsets but seems fidgety?
