Yes it is easy, you must, once you have set your zeros, make a note or take a picture of your offsets. Then if you want to get back to the set position after you have shut down your machine follow these steps;
1 restart and home your machine.
2 open the MDI tab
3 type, g01x… y… The dots are your offsets that you made a note of.
4 press enter.
You should now be within 0.0002 of your last settings.
Hope this helps
