DISCOUNTS:
Day 6 is here (last day) and we have Bonus Discounts for you! No coupons needed! These items will show discounted prices starting on Nov 25th, at 11am eastern.
REDLINE SPINDLE SALE:
80mm 2.2kw : $736.75
80mm 1.5kw: $685.75
65mm 1.5kw: $665.75
ROTARY (4th Axis "Revolution’)
Additional 10% Off
Rapidchange ATC:
Sale Price: $575
JTECH LASER
(Very Limited supply):
24w: Sale Price $1035
14w Pro SI: Sale Price $697
QCW (Quick Change Wasteboard):
Foreman: 247.50
Journeyman: 227.50
Woodworker: 207.50
LEG KIT:
Sale Price: $174.50
ROLLING FOLDING STAND: Sale Price: $247.50
GEN 2 ELITE NEWS:
BONUS: BALL SCREW COVER CUSTOMIZATION FOR GEN 2 ELITE!
With our new Gen 2 Elite Series , one of the biggest upgrades is the all-new Ball Screw Covers . Not only do they do a fantastic job keeping your rails and ball screws clean—dramatically reducing maintenance—they also give Onefinity something we’ve never had before due to our modular tubular design:
Surface area.
And surface area is fun —because we can finally put the Onefinity logo front and center and really make the machine stand out. But then we thought… why stop there?
Why not let you put anything you want on your machine?
After all, it’s your Onefinity.
With the Gen 2 Elite, we plan to offer factory-printed, fully customizable Ball Screw Covers . You provide the artwork (using our easy sizing template), and we print it right onto your cover.
Want to show off your social media brand? Love maple syrup and want the world to know? Have a favorite bit company you proudly support? Have a sponsor or want to sell ad space? Now you’ve got prime real estate to do it. Go for it.
Thanks to the easy, snap-in design, swapping covers takes seconds. Slide your custom cover in, pop another one out—it’s your machine, dress it how you like.
We’re aiming to launch this service in 2026 . Stay tuned—this is going to be fun.
Can I Put the New Elite Gen 2 Ball Screw Covers on My Gen 1 Onefinity Machine?
Before we can answer that question, it helps to understand how we were able to create such a clean, elegant ball-screw-cover system in the first place. The Gen 2 Elite Series wasn’t just a refresh—it required three major structural redesigns that make the new covers possible.
1. Completely Redesigned Gantry Blocks
Our engineers pulled off something genuinely clever here. On the Gen 2, the ball screw cover actually passes through the newly designed gantry block , keeping the cover tight to the screw and shielding it from dust and debris.
To make this work, we also recessed the ball nut into the gantry block itself , which solved two major issues at once:
- It eliminates the stick-out you see on Gen 1 machines
- It allows for greater X and Y travel while maintaining the exact same footprint
This redesign is one of the main reasons the Gen 2 enjoys a noticeably larger cutting area without requiring a larger shop space while still using the same QCW we’ve always had.
2. New “C-Shaped” Bearings (Think Pac-Man)
The bearings that ride the tubes are now C-shaped rather than fully circular.This allows them to nest closely around the ball screw covers and maintain the tight, rigid structure that defines the Gen 2 rail system. The older round-style bearings on Gen 1 machines simply aren’t shaped to make this work.
3. Re-Engineered Feet With Integrated Cover Clips
The feet received several small—but important—structural improvements.These upgrades allow us to mount end clips directly to the feet, keeping the ends of the ball screw covers secured and properly aligned.
Even though each of these updates might appear small on their own, together they represent a near-complete overhaul of the rail system. Other than the tubes, almost every surrounding part changed. Because all these elements interlock, Gen 2 ball screw covers cannot be installed on Gen 1 rails without replacing a large portion of the rail assembly.
Will We Offer Upgrade Kits for Gen 1 Machines?
Short answer: yes. But it’s not as simple as selling Gen 2 parts individually.
Gen 1 machines were built across several years using multiple tube combinations:
- 35 mm tubes
- 50 mm tubes
Meanwhile, Gen 2 uses:
- 50 mm Y-axis tubes
- 60 mm X-axis tubes
Since 60 mm didn’t exist on Gen 1 machines, we can’t simply bolt Gen 2 components in place. We need to develop new, compatible versions that fit the tens of thousands of machines already out in the wild—each with slight variations across years and models.
This takes careful engineering and time.
A Note on Inventory and Timing
Whenever we launch a new product, our first priority is ensuring full machines ship on time and lead times stay short. Launch Week demand is always massive (even with forecasting), so we must reserve parts for complete machine orders first.
Once machine production stabilizes, we’ll have a better handle on stocking upgrade components.
Our track record speaks for itself—upgradability has always been at the core of our philosophy. We expect to share more details on Gen 1-to-Gen 2 rail upgrade paths sometime in 2026 .
Want Gen 2 Features—Like Ball Screw Covers—As Soon As Possible?
If these new features have you excited and you want them in your shop right away , the fastest route is simple:
Order a Gen 2 machine when orders open Tuesday, November 25th at 11 AM Eastern.
We can’t wait to see what you build with it. See you on Launch Day!
Gen 2 Elite Series - Batch 1
From$2,437.75$2,195.75
Buy Now
Can I still use the Suck It (regular or Pro) on the Elite Gen 2 or Apprentice?
This one’s a bit of a trade-off.
To gain the increased cut capacity on the new machines, we redesigned the Z-20 for Gen 2. Part of that redesign was removing the “wings” from the Z-slider. Those wings were what the Suck It (regular and Pro) arms attached to, allowing the dust boot to remain stationary. Without them, the original Suck It system simply has nothing to mount to.
When we developed the new Suck It SM for the ATC, it quickly became our favorite dust boot—stronger suction, easier installation, and it moves with the spindle for more consistent dust collection. Because of how the Gen 2 Z-axis is engineered, the Suck It SM is the only dust boot compatible with the Elite Gen 2 and Apprentice Series.
We feel the loss of the old wings—and compatibility with the original Suck It—is absolutely worth the gains in cutting area and performance. And honestly, the Suck It SM really sucks (in the best way).
Since launch, the Suck It SM has only been available in an 80 mm version. Thanks to customer feedback—and the needs of the new Apprentice Series—we now also offer a 65 mm Suck It SM !
Launch Week Orders open November 25th at 11am eastern.
(items will show ‘out of stock’ until then.)
Chat with the community in the official forum thread!
Launc Week 2025 Recap:
DAY 1:
Jenny Bits - “Together for the Holidays” Promo Pack 2025
DAY 2:
AirWeights QCW Vacuum Slats - Same System You Love, More Affordable Than Ever!
DAY 3:
Introducing the Onefinity CNC QCW Heavy Duty (HD) Leg Kit
DAY 4:
Redline Controller Upgrade Kits For All Onefinity CNC Machines are here.
DAY 5:
Introducing the NEXT GENERATION of Onefinity CNC
| Welcome the GEN 2 ELITE and APPRENTICE Series
Introducing The All New APPRENTICE Series by Onefinity CNC
Introducing The All New Gen 2 Elite Series by Onefinity CNC.
Day 6:
Discounts!
The Question Everyone is asking. Where’s the 4x8?
Launch Week 2025 was all about perfecting the new Gen 2 Elite Series —stronger mechanics, updated components, refined motion, and a fully modern controller experience. Before introducing a brand-new 4×8, we wanted the entire product line to sit on the same foundation. Now that Gen 2 is locked in and performing exactly how we want, the Full Eight becomes its own dedicated product—built from the ground up as a true 4×8 solution. And yes, for those who already own a 4×4 Foreman (Elite Gen 1 or Gen 2, Redline or Masso), the Full Eight will also be available as an upgrade path , letting existing Onefinity owners expand to 4×8 without buying an entirely new machine.
Unlike other 4×8 machines on the market, Onefinity is committed to ensuring your current 4×4 isn’t something you have to scrap and replace. Our goal is full compatibility across multiple generations—even machines that are years old—so you can build on what you already own. Achieving that level of capability and compatibility takes time, and we’re working hard to deliver the most flexible, most powerful, and most accessible 4×8 upgrade path on the market. We expect to share more in 2026, and we appreciate your patience as we do this the right way.
End-Of-Life Update:
The Original and Pro Series (with the BB Buildbotics controller) have officially reached end-of-life . They served the community incredibly well for over five years, but with how far our machines and controllers have advanced, it only makes sense to focus on the Elite and Apprentice Series moving forward. Thanks to the Redline controller, we’re able to offer the far-more-capable Elite Gen 2 machines at the same—or even lower—price than the Original/Pro lineup.
And don’t worry for a second: we provide lifetime support for every Onefinity ever made. If you own an Original or Pro machine with BB controller, you’re still part of the family—we’ve got your back, always.
