Limit Switch Repair
Hi all,
Is it possible to remove the limit switch from its housing? As you can see, I failed to implement cable management and broke the wire. I don’t think I can solder this in the housing. A $60 mistake I’ll not make again. Thanks all.
If you have enough extra wire, id solder them up and either tuck them in the channel or make a little grove and tuck them in the cavities on the sides
the limit switch is just pushed into the housing. You’ve already removed the two silver bolts holding it in, now just pry it out.
Thanks, all. The new switch will be here Tuesday. I realized what I thought was a bare copper wire on the switch side was the white wire. I’m afraid of a short with a break in the insulation beyond what’s visible. I was able to get the sensor out of the case and solder them up. I’m afraid of damaging/destroying a motor or the Masso controller (I think I saw it was $1,800 to replace). I’ll keep the repaired switch just in case, but I’m going to wait on the new switch. Thanks again all.
