Elite J. Easy way to relocate power button?
Is there an easy safe way to relocate the power button on elite to add it to an external control panel? Basic solder skills. Anybody have any resources or advice?
Have you considered using one of those smart receptacles and key fob style remote to turn power on and off?
Since it’s a toggle push button, would that work? Do you have to change a setting or something?
You stated you have an Elite model which i believe means you have the masso controller (as i do). I just double checked and pushing the button in to power it on, i can turn it on or off by plugging it in or pulling the plug out. So as long as you use a smart plug rated for the amperage needed, i think this should do what you want.
Ah yes you’re right thanks. I didn’t look at the button close enough. I thought it was momentary but it actually stays in after pushing it. That should solve it. Thanks again.
