I have 2" stock which I have been working on. I am trying to drill 4 holes which will go through the material and into wasteboard. I have a 4" bit for Makita router. . After raising it all the way I still have plenty of clearance between the bit and material. After probing Z, router goes all the way up and then try to go some more. I didn’t realize that the first time so when I started bit hit the material far too early, and thankfully that was a piece of wood I am going to cut. I tried again to probe Z but same issue.
Anyone has any tips / tricks or do I need a shorter bit? 2½ inch isn’t long enough so a 3"?
Thanks!
