Machine not stopping for tool changes
Hi everyone,
I want to start by saying I’m brand new to the CNC world, so please forgive my ignorance.
I just bought a new Foreman Elite (Redline Bundle), and I’m having an issue where the machine doesn’t stop to prompt me for a tool change when running a program with multiple tools.
I’ve created a single program using Fusion and the Redline post processor, and no matter which settings I choose, I can’t seem to get the machine to pause for tool changes. It just moves to the next tool path and starts cutting as if the tool was swapped out.
I’ve made sure all my tools are numbered uniquely in Fusion, and I can see the “TX M6” line in the g-code where the tool change should happen, but it seems to have no effect.
What am I missing?
Thanks a lot!
Did you set up tool change in the tools menu of the controller?
I did not. Sorry, like I said, I’m brand new to this stuff. I thought that menu was for the ATC (which I don’t have). Anyway, is there any documentation on setting up tools in the controller?
Thanks a lot!
I’m using a BB controller, but I gave up on using tool changes in one program. I make separate programs for each tool and put them in one folder, then load that whole folder into the controller. The machine has to stop and you need to rezero the Z axis for each tool anyway, so loading a new program doesn’t add that much time.
Were you able to figure this out? I am having the same issue.
I think tool changes are not supported with the free version of Fusion? Is that what you are programming with?
I am using Aspire. I never numbered my tools which may be an issue, but what I did to fix was update the post processors on my Aspire software to the latest Redline. That with setting my tools to reflect the Onefinity on the top dropdown of the Aspire software when doing the tool selection in CAD. That itself seemed to do the trick. I was then able to setup my eazy z on the onefinity CNC.
Hi, I just worked through this same issue with my Gen 2 Redline running on Windows 11. Apparently this issue is known (by some) but the fix was to edit the gcode file and put the TX on one line and the M6 on the next. It works fine but I wish someone would either correct the post processor or the Redline app. Also from what I read is the TXM6 on one line works on the Masso so the fix might need to be in the RedLine app.
