Milling aluminum on the Elite Woodworker 32x32
Hi,
I want to use the Elite Woodworker (32x32) to mill aluminum parts. The stocks we normally use are 6-10 MM thick, with sizes of upto 180x80 MM. The max milling depth is not more than 20 MM. I understand the cutting rate will be small, however this should not be a problem as we will be mainly using for very small scale production.
I just want to know if the CNC machine, and the bits can hold up to the strains of aluminum milling. I intend to use air blaster/maybe cutting fluid as well, with single flute endmills.
Any thoughts?
Thanks
a
From my recent tests milling aluminum on a WWX50, the greatest challenge to overcome will be rigidity and deflection. I am learning to use F360 CAM, and am having success with multiple finish passes. I try to reduce the end mill stick out as much as possible in my tool holders as well. I mill dry, with air to remove chips, and currently use one and two flute 6.35mm end mills. I am still developing the best tool paths for the operations I plan to use.
Any quality carbide bit with the correct feeds and speeds can handle aluminum.
How about the machine? Is it rigid enough to handle the strains of milling aluminum?
Without a doubt. I did some deflection tests when I first got my machine and it took quite a lot of force to see
deflection in the rails. Basically sitting on the X rail would deflect less than 0.003" at the center. I think what @TMToronto mentioned about bit stick-out is going to be much more important.
I recently did a project milling small channels in aluminum… that was my first try at it. I was using 1/16" single flute endmills… I had to slow the feed rate down more than I thought that I would have… I broke 4 bits in the first 15 minutes, then used the same bit for 4 hours once I got it slowed down and dialed in. There is a learning curve, but the machine will do it. BTW, I was using a Makita router and cheap Chinese made carbide endmills. Needless to say, I would not recommend starting the project with your new $50 bit. Oh yea… I have an X-50 Journeyman (not an Elite Woodworker), but I believe the answer is the same.
Bill
My main concern was never so much downward forces on the gantry, rather the additive ‘play’ introduced in the combined X and Z linear bearings, and the resulting deflection caused by lateral forces when milling. That is why I am finding the effective use of spring/finish passes, as well as conventional and climb milling, are so important. I know I am looking for tolerances and finishes best suited to a different type/class of CNC, but I still strive for the best. In my experience it just takes longer and means less room for error when setting cut parameters.
