Motor resolution change - manual update?
DIPs are set 1 & 4 to low (off), the others are set to high (on) with respect to all motors. The .htg files that I downloaded were for the Foreman which is the machine that I purchased. HTG file loaded successfully as X, Y, and Z axis indicate on the Drive: Pulses Per Revolution are 2000.
What should the ball screw pitch be set to and where can I verify/change?
Additional Info:
Motor Distance Per Revolution
X = 0.62992
Y = 0.62992
Z = 0.39370
Would really appreciate OneFinity to weigh in on this…Here is another example, pretty simple carve, just a bunch of triangles. After the carve completed, and when the spindle was coming home, a soft alarm on the Z-Axis popped-up.
That is a soft alarm on Z axis, not x or y (left to right/front to back).
You most likely have something set in cad (maybe safe z height) set to too large.
