I have my woodworker sine mid-2021 (BB controller). And last year I also bought rotary and Redline spindle. I have barely used my woodworker in these years and have not even started with Rotary or the new spindle after I installed them. Like most of you I have the same problem - only 24 hours in a day!
Long story short, I think now I can regularly spare a few hours a week for my hobby. I want to start with rotary and would really appreciate some handholding. What I am looking for is a small project file (g-code) that I can use to try out and gain some confidence in operating the rotary (and the spindle) - some very basic work, even if it is just making a dowel out of a 4 x 4 woodblock.
Any additional advice will be an added bonus for me.
I have limited experience with F360 and don’t have or used any other software.
I searched YouTube and got multiple results. I could not really figure out which one was the correct one. I checked a few of them but did not find any relevant stuff. There is one M&S Woodworks who has a video on rotary project, making chess pieces using premade models that he bought from a site. That is a too big of a project for me.
Can you provide me the link to the site you mentioned?
Deskproto is good but I find the workflow in the application a bit clumsy having used F360. But I’m getting used to it.
You need to create your own gcode, it is the only way to learn and to use your own CNC.
I would also start with regular non-rotary CAD and CAM if you are new to CNC. If you want to do rotary then start with Vectric or Deskproto for non-rotary.
@PezWoodworks I am using F360 and not ready yet to spend money on software subscription. I found some information and videos explaining the rotary work in F360 and I will go through them and hope I will learn something useful.
@AndyP I feel comfortable using F360 for 3-axis milling up to a point where I think I can find my way if I am stuck at some point. It is the use of rotary that makes me a bit nervous.
I think I will just try to do some manual work and perhaps use individual g-code commands to operate it until I gain some confidence. At the same time, I will also keep trying F360 to generate code for rotary.
And yes, I will also use ChatGPT to help me in this!
Sounds sensible. In which case you could try index milling, using the rotary to turn the piece to a number of milling planes thus doing 3axis milling. You will need to make sure your centres are spot on center.
I’ve seen video where someone turns the piece 120 degree twice, that is three F360 Setups. Midi the 120 degree rotation.
