So I started getting into VCarve inlays and due to how dead on everything has to be I have realized my XZY probe isnt flat. I am wondering what is considered “flat”?
My variance is .5825” to .5860” as I move my calipers around. Would y’all call that flat enough? I can feel ridges on the machined side which is another reason I decided to check a few different ways to see the different readings.
For the record, it actually does make a difference on some cuts. The reason I did it was because, while attempting to make a box by folding plywood, I couldn’t make the 60* V-cut with enough accuracy to reliably obtain 0.010” remaining wood at the bottom of the cut. Localizing the Z axis probe location provided better precision.
