Onefinity CNC Easy ATC Work Surface Mount STEP File (FAQ)
Installation of the mount will require boring holes for the two ¼:” (6.35 mm) locating pins, and spot drilling the location of the six #7x1 ½” wood screws used to fasten it to the table. We have a STEP file of the Work Surface Mount base available so that you can create these two toolpaths using the CAD/CAM software of your choice.
Single Mount
Easy ATC table riser template_.step (55.1 KB)
Double Mount
Easy ATC Dual Work Surface Mount Template.step (106.3 KB)
SVG for Double
Easy ATC Dual Mount SVG
