Onefinity now sells Vectric Spark for Mac! Works with ALL Onefinity machines!
Vectric Spark is Vectric’s first native macOS CAD/CAM software, giving Mac users a powerful but intuitive solution for designing projects and creating toolpaths for their Onefinity CNC—without Windows or Parallels. Spark combines 2D design tools, CNC toolpaths, V-Carving, laser toolpaths, machine setup, tool management, and realistic toolpath previews in one streamlined Mac interface.
This is great news for Mac users. Having native macOS support means there’s no need to rely on Windows or Parallels just to create toolpaths. The V-Carving and laser tools in the same app are a nice bonus too.
So, is there any idea if or when the Vectric Spark software will be able to control the RapidChange ATC? I am an avid MacOS user (since 1994) and really do not want to get a PC to run the Gen2 Foreman I have on order (ships in November 2026). I thought I’d ask here first and see if anyone knows or has an idea. Thanks, Charlie in Central Florida
HI Charlie,
The CAD doesn’t controller the rapidchange atc, the controller does. It’s built into the redline controller!
Thanks for the fast response…
So, being very new to CNC - this will be the first CNC I actually use, so will I be able to use the ATC with the Vecric Spark software?
And, if I will, will I need to program additional steps into my designs?
Thanks,
Charlie
SlotCarRacer.com on Facebook https://www.facebook.com/pages/SlotCarRacercom/155076827890709
HO slot car racing in Central Ohio… http://groups.yahoo.com/group/CentralOhioHORacing/
Someone replied to your post.
| OnefinityCNC Onefinity CNC Official :white_check_mark: Leader
October 20 |
HI Charlie,
When you do your toolpaths and chang bits, the machine knows what bits are where in your ATC and will get the right bit when they need it - that is why you pick the controller in the software, so it knows how to write the Gcode to make it all work.
OK< I believe that I understand that. And, of course being new, I will definetely not being using the ATC right from the beginning !!
Charlie
| WmHipple
October 20 |
I have been trying for several hours to integrate my Redline ATC into my workflow with Vectric Spark, without success. I have tried downloading and installing the post-processors from Post Processors - RealTime CNC and ensured that the tools are number correctly, but still Spark resists creating a single g-code file. I’m using a very simple project (the Welcome sign) to implement this. Has anyone successfully implemented the Redline ATC with Vectric Spark?? Thank you!
what about the pre installed post processors - it says it uses the same ones as the other Vetric products, so I can’t imagine not having it - also there are redline and masso builds that are not onefinity, so make sure you choose the Onefinity version of Redline and/or Masso
The two compatible post processors are “Onefinity Realtime RTSX (inch)” and “Onefinity Realtime RTSX (mm)”. Neither allow tool changes, in spite of tools being properly numbered. The product is simply incapable of it. I’m trying to get standing on the Vectric Spark forum so I can post a query there. It seems to be an incomplete product and I’m not happy having paid full price for it - it should have been a free beta until they added ATC support. Among a LOT of other things that I won’t get into here (off-topic).
Yeah, they said from day 1 Spark doesn’t do ATC - at least not yet…
They didn’t try and hide it - https://www.onefinitycnc.com/product-page/vectric-spark-for-mac-perpetual-lifetime-purchase
Not trying to be a dick but basically you are complaining about something not having a feature after you bought it but didn’t research the product first. This is entirely an issue of your own making, eventually it will be added be patient or use another cam software
@WmHipple - Crap - well, I missed that as I was racing to hit the “Buy Now” button, clearly.
@LFwood - That’s a fair comment - in my eagerness to adopt a macOS CAD-adjacent solution I missed the “caveat emptor” section on the Vectric Spark site.
Don’t get me wrong - Spark is very nice software and (hopefully) will receive feature updates.
So, on a related topic, then, would it be feasible to merge the separate g-code files produced by Spark in a text editor and insert the appropriate commands?
You could just do your gcode in separate files then do a “manual” tool change with your ATC. I mean you should be monitoring your cnc anyway, so a few key strokes in between tools shouldn’t be a big deal. You can manually change the file to add to changes most likely but it would be faster in my opinion to just do the “manual” tool changes and separate gcode files. Unless of course you plan on making 1000 of whatever you are making.
I like what you are saying about editing the files, or using a series of files. However I could use a training course covering details of what’s involved. Especially since in general that could fix a whole host of issues or add flexibility.
Usually a tool change is triggered by an “M” code along with the tool # within the body of the gcode. Couldn’t you manually enter this? I don’t currently own a Onefinity but looking to purchase. I do have years of experience using CNC equipment.
Is there a plug and play z axis touch probe
The Realtime Controller is a bit different but the same…
T{#}
M6
They have to be in that order, and on seperate lines.
FWIW, I use Grok quite a bit to troubleshoot and learn about CAD, CNC, G-code, etc.
So does the software and post account and/or allow for tool changes? Take a look at your gcode file. It’s an ASCII based file and can be opened in any txt based editor like notepad or which ever NC editor of your choice. You should be able to see the transition from one tool to the next. If the Redline controller recognizes tool changes, then add accordingly
T#
M6
