This is important for anyone who is doing modifications (not supported by Onefinity and done improperly can permanently damage your controller, voiding the warranty) to their wiring like drag chains.
There is a cable cross in all motor wires. On the X and Y wiring sequences, the center curly cable shown here is instead a straight cable contained inside the x and y metal inner tubes.
Operation must include the inner wire. Direct connection to the stepper motor (without the inside wire) will damage your machine and cause the stepper to not operate.
Improper wiring will damage your controller and void your warranty.
Aftermarket cables should not be used and will void your warranty!
Wiring diagram 2.pdf (956.4 KB)
