Trying to draw a circle around a logo and break it so logo passes through part of circle.
But getting open vector when trying to create tool path?
Ty
Hi Frank - what CAM program are you using? I’d recommend closing the connection outside the main project if you can. Run a line outside the project, and close the vector. Hopefully that makes sense.
I’m using Vcarve. So I have my main logo vector, and I did a Circle around it and drew 2 lines and cut the circle where needed but then I get the open vector window error when i go to create tool path?
If i leave Circle closed tool path works fine?
Thank you
Frank
Hi Frank - simply keep the cut lines - that will keep the neutered circle closed and place for the router to go. Make sense?
