Pocket Hole for Picture Mounting Screw
Is it possible to create a Tool Path for carving a pocket hole, or keyhole slot, with my slotting bit?
I need the bit to plunge .375" on Z, move .500" (on x or y), to create the slot, and then return .500" to clear the slot, and then rise the .375" to clear the hole.
I hope you can see the copied photo of the picture hanging slot i created by manually jogging the router.
Thank you, Ray
If you are using Vcarve you can create a profile toolpath that’s U shaped (about 1/32" wide)
that will perform the slot cutting process in a single pass.
This one I designed for my particular slot cutter you may need to modify based on the cutter you have.
Keyhole 375 x 75.crv (21.5 KB)
Ken5;
Thank you for your reply. I will try your file. Your explanation sounds so simple I wish I coulda thought of it!
Ray
V-Carve has a keyhole “gadget” that does this automatically - I’ve used it several times, and it works great.
Creating a little jig to do this by hand with a trim router is super easy, though. Tons of YouTube videos like this one explain it well: https://www.youtube.com/watch?v=3WVh1HqdrmY
Had something too big for the CNC that needed keyholes, and the little jig worked well. This is how I will do these from now on - the CNC just doesn’t add any value to the process.
Pretty much agree with you on this. Unless I’m doing a ton of them in the same project file, the time it takes to replace the bit, re-zero and run the operation is more disruptive to my workflow than just popping a jig on and doing a quick router operation. I have a few trim routers so keeping one with the keyhole bit permanently installed is easy enough.
That works;
Thank you
Thanks for the introduction to gadgets.
If you only need 1 or 2, it would be about as easy to do it in manual mode.
Agreed.
However I often flip my work piece over for a date and signature carve anyways.
Ray
You can actually do this with a simple profile line. Start at one point, click, then go back back on the same line. Just remember to start where the hole will be, and when you run your toolpath, check the “keep vector staty point”. Thats how I do mine.
Awesome trick, to get the bit to return to its origin.
Ray
