Anyone with a Vevor or similar CW-3000 “Industrial Chiller” knows the issues with the flow sensor. There’s a post on here that details how to rearrange the internal plumbing to help mitigate the false alarms. I did those mods and I would still get annoying alarms from the chiller far to often. I was constantly having to raise the front an inch or so with my foot and drop it to get it to shut up. I finally got tired of it and decided to do something about it.
Trigger Warning:
This project is vibe engineered and vibe coded. If that bothers you, go ahead and leave your snarky comment and then move along. I’m a CAD guy by profession and a CNC guy by hobby. Without the help of ChatGPT I would still be trying to figure out how to get the Arduino to say Hello World on the OLED display. You’ve been warned.
So after much back and forth with ChatGPT I finally let it convince me to give this a go. I essentially replaced the offending On/Off flow sensor with a hall effect flow sensor. I had just replaced all of my external coolant lines and put in fresh distilled water with Mayhem’s Hades+ and Inhibitor+. This is the same stuff gamers are using in water cooled PC’s and is less finicky than window washer fluid which I had been using and less hazardous to pets than antifreeze should there be a leak.
The hall effect sensor is read by an Arduino Nano which displays the actual flow rate on a 1.3" OLED display on the front of the chiller. As long as the flow rate is within an acceptable range a relay closes taking the place of the old On/Off sensor so the original chiller alarm is still functional. That would have been enough to fix the false alarm problems, but that would not have been over-engineered enough so I decided to add a real time clock module that will notify me after 90 days that it’s time to add more Mayhem’s (per their recommendation). After 365 days it will tell me to do a full coolant replacement. Going one step farther I put in a some leak detection probes in the bottom of the case so that the alarm will sound before all of the water is pumped out. Granted, that only checks for internal leaks, but the only leaks I’ve ever had with this thing have been internal so…
If anyone is interested I have a schematic and I’m more than willing to share the Arduino sketch and a Bill of Materials. Not counting hardware, filament, wire and various shop stuff I’ve got about $61 in it which is about half of what I paid for the chiller originally. That said, buying the stuff on Amazon I got more than one of everything so I’ve got lots of left over parts for future projects.
This has been a fun and hopefully useful upgrade. Time will tell. I will update this post after I’ve put it through its paces, but as of right now it’s working like a charm. Feel free to ask any questions and I’ll share all I know.
Without further ado, I present to you the Vevor CW-3000 Pro Max³.
~Doug
It wouldn’t be complete without a new label.
The 3D printed carrier board for most of the components.
The new hall effect sensor mounted on the inlet line.
Leak detection probes.
