Tubing or alternative connectors for Vevor CW 3000 water cooling system.
Recently purchased a Vevor CW3000, and I overlooked that the connectors in the rear don’t align with the 5mm ID of my Huanyang spindle. It appears the Vevor has an outer diameter of 10mm and an inner diameter of 8mm. Has anyone employed this chiller and successfully adapted it to function with Huanyang-type spindles?
I have a different model of both. I did not want to modify the chiller, so I joined the two hose diameters with barbed brass reducing fittings. The flow rate remained in the range required by my spindle manufacturer.
Hey zhilen111,
see here:
Anyone using the Vevor CW3000 water chiller for their water cooled spindle? – Post #47 by Andreas (@carveman)
By the way, we have a search function here.
CW3000
Welcome to the forum!
