Spindle Coolant Flow Alarm
Does anyone use a flow sensor with cable fed to the Masso touch? Was reading up on the “configureable inputs” among many other options, this one seems like it would be a neat feature to ensure you for sure have coolant flowing for your spindle.
  • From the Masso documentation-
This input monitors the coolant flow sensor and will signal an alarm condition if the input changes to High for 10 seconds or more when the spindle is running.
MASSO will enter Feed hold and Spindle Coolant alarm will be displayed.
To clear and reset the alarm you must Home the machine
I use a CW-5200 chiller with my ATC spindle and Masso G3. I have the flow alarm wired to the controller and it works as expected.
That’s awesome to hear! really appreciate the feedback. I recently ordered my machine and eagerly await its delivery so I’m reading up on additional details.
I also saw a post online that someone wired up a small panel with some buttons, that were configured to execute certain behavior, I might look into that too, seems kinda neat to have “quick shortcut” buttons for common things, but maybe it 100% unnecessary, ha.
I have a ‘temporary’ mock up control panel at the front of my table that I have been using for quite a while now with my build, and it is working quite well with my work flow. Besides toggle switches for manual ATC functions, I also have a programed USB keypad with a dial that is proving invaluable with the Masso controller. I use it for certain keyboard shortcuts, and it makes switching between F12/F13 and overrides especially quick. I had purchased a mini keyboard, but like my pendant for many of the other keyboard functions related to axis movements. I also have my VFD keypad, controller USB, and a few vacuum controls/sensors there as well.
That’s so cool! holy cow!!!
What resources (if any?) did you reference to learn about the wiring / setup?
The short answer is … everywhere. Masso forums, online articles from manufacturers, many YT videos, product user manuals, etc…
I have been building and modifying my set-up for a few years now. If interested, I have shared most of it in the Onefinity forum - search keywords 'Masso G3 ATC build update…" for a bit of the journey.
I will for sure check out your build! Thank you for sharing that.
I purchased a Vevor CW-3000DG and a chiller alarm cable. The Vevor was roughly half the price of the S&A
I’ve got it hooked up using the instructions. Black wire to Input 10 and Red wire to power. When I turn the chiller on it alarms because I haven’t put coolant in it yet, but the input on the Masso is not going High like it should. Any ideas what might be the problem?
These units appear to all be identical with different labels stuck on them. The user manuals for both the S&A and the Vevor are identical.
I believe it works like an E-stop circuit - when all is working the circuit is HIGH. This way if the power fails or circuit is accidently cut it goes LOW.
Does the input go HIGH after you get it up and running properly?
I have one, it’s nice.
I found an inline sensor and use it with my pump. Doesn’t matter if it’s feed or return line, as long as the arrow follows the flow
It looks for if the input is static so it alternates low/high
It may have been my wording.
The chiller alarm circuit itself will provide +VDC (in my case 24VDC from a PSU) when all is good, just like an Estop, so it is considered a fail-safe type circuit. I believe it’s internal relay bridges pins #1 and #3 in this ready state.
The difference is that in the F1 screen, Masso expects the Estop to remain in a HIGH toggled state, but the Spindle flow alarm needs to be toggled LOW, when all are working properly.
That’s right.
I’m using the pulse alarm where if it stops pulsing for 10 seconds, it’ll alarm.
