Probe any corner for XY zero work position
Allow XY touch probe to work from any corner. Like the Masso. Need this feature when doing two sided work!!!
wait . What? are you saying you cant probe from any corner with the redline?
No matter if you have BB, Masso, or Redline, you can only use the xyz touch probe block in the lower left corner for xy probing at this time
I never knew that . I have always used the corner or centered the bit by eye. huummph
You can, of course, manually zero xyz on all three machines anywhere.
I probe top left on my Masso all the time. The trick is to ensure that your probing block offset is accurate and equal, so that when you rotate the block for other corners the measurements stay accurate. Mine required some precision milling. Thankfully, we all own a CNC that can do that!
Not true. Masso let you zero from any corner while using touch probe
Probing any corner is on our development roadmap. It seems like there is quite a bit of interest in this feature, so I will make sure it gets punted up the priority list. I will also provide an update in this thread when available.
