Quality of 3D carves
I’ve had my 1F Elite for a few months now. It has a spindle.
I’ve noticed that my 3D carves are not very smooth. I’m using a Taper ball nose bit at 10% stepover. I get areas that are pitted and grooved and at random spots the height of the carve changes. I have a smaller leadscrew machine that produces better results than the 1F using the same bits.
The 1F is on a torsion box so the base is solid. The spoilboard has been levelled.
Everything appears solid. I’m stumped. The STL doesn’t have these artifacts in them and when carved on my other machine, these artifacts don’t appear.
I’m looking for any assistance people might have. Thanks in advance.
They appear quite random. I’ll check the set screws, thanks.
The set screws on z-axis are tight. Nothing appears loose.
That’s odd, I make a lot of chess pieces using my Rotary and they come off the machine needing very little to no sanding, I use a tapered ball nose with a 1/32 tip radius and a .003- .005 step over for the finish carve.
I have the Elite woodworker and a cheap Chinese spindle and VFD.
I do use good hardwood like clear walnut, hard maple and African Blackwood.
I will be interested to see what you come up with.
Pat
Those are outstanding. Beautiful color and finish.
You might look at how much end play you have in the Z axis, the Z is different than the X and Y which use a nut on the opposite end of the ball screw to tighten up just right (pretty subjective in my opinion)
The Z however is set by the engagement of the motor drive coupling, if you gently pry up on your spindle nose meaning the collet nut without a tool in it, there should be no upward movement in the spindle, if there is you would loosen the set screws on the coupling and move it toward the spindle to limit end play.
Hope this makes sense.
Pat
When I replaced my Z assembly I can confirm mine had approximately 2 mm of vertical play.
Mine was the opposite which was why my spindle did not drop on power off, the motor/coupling was preloading the thrust bearing.
Pat
Interesting. I will have a look at that.
I’ve checked the z-screw coupling and there is no play in it.
I’m going to reduce the acceleration to see if that makes a difference.
Here is a look at some cherry that was surfaced with a 1/32 TBN bit at a 10% step over. It’s rough to the touch.
Here is another picture of some walnut.
Are you using the stock stepper motor resolution settings? I’ve changed all of mine from 400 steps/rev to 4000 ste0s/rev, and the difference is noticeable.
This would be a stretch but are the spindle bearings good, I mean you should not be able to feel or measure any side movement at the collet.
Pat
I’ve changed the z-axis resolution to 800. The walnut picture was carved at 400 resolution and the cherry was carved at the 800 resolution. I think I see a difference between them.
I’ll experiment with greater resolution. Thx.
I have a spindle. I love it
Hey Peter,
What speed and feed are you using and how sharp is the tip of the cutter?
The cherry piece looks like there could be some tearing of the wood, but the walnut piece makes me think surface tolerance may be too loose. Does your software allow you to tighten the tolerance?
For both pictures the feeds/speeds were 250ipm.
I use Aspire and I’m not sure what you mean by surface tolerance.
On 2D work there often is not any tolerance setting.
Since it is a 3D surface the software will have a tolerance that it allows the cutter to deviate away from the surface. So the cutter is allowed go above and below the surface by that amount. So look for something called tolerance in your settings.
If it has accidentally been changed to something like .005" (.12mm) I would expect the finish to look like that. I keep my finishing tolerance at .0004" (.01mm)
A quick internet search says for Aspire it is under Program Options → Toolpath settings.
Mine defaults to 0.0004"
