Question re: putting new bit information into Carveco
Hi, I just purchased the Amana tool - 56144 Carbide Tipped Point Cutting Roundover 1/2 Radius x 1 Dia x 3/4 x 1/4 Shank Router Bit
The link to the tool is here: 56144 Carbide Tipped Point Cutting Roundover 1/2 Radius x 1 Dia x 3/4 x 1/4 Shank Router Bit
I looked through the carveco amana tool database but I couldn’t find this bit. I want to enter the data in manually, but I’m unsure on what some of the values should be. Could anyone help me out with this?
Cheers,
Zain
I would recommend reaching out to Carveco Support. It would also help to specify which of the values you’re uncertain about when contacting them.
You should contact Amana, not Carveco, they don’t grind bits.
