Rapidchange ATC tool-stick-out
I do not understand the 24mm tool stickout on the Rapidchange ATC.
Can someone explain where the max stickout is measured?
24mm tool-stick-out measured from the collet would be a dealbreaker for me. That is definitely not enough.
In that case I hope Onefinity would cancel my order.
The 24 MM stickout is if you don’t drill a corresponding hole under the tool pocket where the magazine is mounted, I have 2" more tool length under mine.
Pat
