Hi all, I’ve had my Journeyman for a few months now. So far it’s been signs, a couple of cutting boards and some V-carving, all 2D/2.5D.
I’d like to try my first real 3D carve. My grandparents’ farmhouse had a front door with a carved panel, oak leaves and acorns around a center rosette, roughly 10" x 14". The house was sold years ago and the door is gone, but I have three photos: one fairly straight-on, two at an angle, and one where the door frame is visible so I can work out the scale.
I want to carve a version of it into a cabinet door panel in cherry, max depth around 1/2".
Where I’m stuck is the step between the photos and something I can toolpath:
- paint a grayscale heightmap by hand over the straight-on photo?
- model the leaves properly in 3D and export an STL?
- or is getting a depth map straight from the photo good enough as a starting point if I clean it up afterwards?
Also curious about the carving side: for leaf edges that should look crisp rather than melted, would you finish with a 1/8" tapered ball nose, or go smaller? And what stepover do you use on cherry for a finish pass that doesn’t need much sanding?
Thanks, and sorry if this is covered somewhere, I couldn’t find a thread that matched.
