Removing X Axis or Y Axis stepper motors
Hi There,
I’m going to be swapping out the stepper motors on the Y Axis, and X Axis of my woodworker.
I’ve detached the 4 bolts that connect to the motor, but wasn’t sure is there is a hidden coupling inside the block that is holding onto the motor yet?
How do you go about removing the motor, and reattaching one?
Thanks,
Matt
When you remove the motor, one half of the spider coupling will remain on the motor shaft. The other half of the coupling will be attached to the ball screw, and seen recessed inside the aluminum block. If your new steppers have the same shaft diameter and shaft length, replacing is as easy as attaching the half coupler on the new motor shaft, and reinserting/reengaging the motor. You may need to take some time to adjust the placement of the coupler halves to make sure they are fully connected when the motor is bolted back on to the block.
Thanks for the input.
This really helped clear up my question:
https://www.youtube.com/watch?v=BffGpb-u5xM
I had used that video myself when I replaced my steppers a while ago, as I was replacing the entire coupler and needed to know how to access/attach the ball screw coupler half. Are you doing the same? If not, I do not think you need to disassemble, but it is still great to know how it is done.
It looks like the video was removed. Do you know if there is another one. I’m trying to replace a stepper motor and want to make sure I’m doing it correctly
I am replacing the stepper motors to upgrade from 1F pro to Elite. Removing the motor seems straight forward except for the wiring. How do I disconnect the wiring? X & Y rails
Thanks TMToronto but I found the answer in 1F video
Hey T,
Remove_screw_farthest_away_from_the_motor_on_bottom_of_front_foot_
Support: How to Access the inner tube motor wire – Youtube
See also
Yes, I am puzzling over how to more easily service/check wires and connector or even to replace a stepper motor if the need exists.
