RESOLVED: X-Axis Showing Incorrect Travel After Stepper Resolution Upgrade (Elite Foreman, X-50)
Hey folks — just wanted to share this in case anyone else hits the same wall I did.
Issue:
After updating to firmware v5.10 and following Onefinity’s instructions to upgrade my stepper motor resolution from 400 to 2000 steps/rev, I ran into a persistent problem:
My X-axis was reporting way less movement than it actually made (e.g., jogged 12", screen said 2.28").
Y-axis was working fine.
What I did (and triple-checked):
- Followed the updated service bulletin from Onefinity
- Changed the dip switches on all motors (X, Y, etc.) to the correct 2000 steps/rev config
- Loaded the correct factory default
.htgfiles via USB - Set Distance per Rev correctly (
0.62992"for my X-50 rails) - Rebooted through Masso’s UI after every change
- Even used the “Distance per Rev Wizard” to test
But the X-axis movement was still way off.
The Fix:
Turns out the final problem was this:
Masso does not fully apply changes to step resolution or motor control timing unless you physically power-cycle the machine — a soft reboot isn’t enough.
But there was one more thing:
Before that final power cycle, I decided to press down a little harder on the X-axis dip switches, even though they looked like they were in the correct position.
That must have done it — after the power cycle and re-setting Distance per Rev to 0.62992", everything worked perfectly. X-axis now matches actual movement and matches the screen readout.
Pro Tips If You Run Into This:
- Make sure you firmly press the dip switches — sometimes they look set but don’t fully engage
- After updating config files or distance per rev, power the controller off completely, not just reboot
- Use a Sharpie mark on the screw + nut to verify real rotation vs expected travel
- The 2000 steps/rev setting must match your physical driver switch settings, or Masso’s scaling will be way off
Hope this saves someone else the 3 days of head-scratching I went through.
Shoutout to @OnefinityCNC and to ChatGPT for helping decode what was going on.
— Cody
