X not equal to Y (solved, adjust trav per rev with an x-50 x rail)
Hello, When I move X and Y manually from the command touchpad (example 5’‘) The Y moves 5’’ but the X moves 8’'. How I can calibrate th
e 2 axes equal? Anyone knows? see my picture
Hey Yvan,
this may be a duplicate of X-axis positioning issues
5x1.6=8…you have a 1616 ballscrew in your X axis now yeah? Upgrade to X-50 Rail? You need to adjust your travel per rev in the motors tab
You most likely have the updated X-50 x rail which requires adjusting the x settings for the ball screw:
Hello Aiph5u, thank you for your anwers. Finaly it is about the X-50 Rail that I have. I have to change the travel rev of the x motor from 10mm to 16mm. Everyting is fine now
Hello Alldaysammyj, thank you for your help. Yes you are right about this. It is working now .Thanks
Thank you very much for your help on this. Now it is working perfectly! Thanks
