I created the Microjig spoil board for my Elite machine. I have the Revolution Rotary 4th axis with the QWC mount. The issue I am running into is the way the spoil board mounts to the table makes it too high for the QWC rotary mounts to work. Has anyone had this issue and come up with a solution? It seems like I either need to find a way to raise the QWC mounts or a way to lower the 4th axis.
Well I just wanted to update this with the solution that I came up with. I have yet to run any jobs with the rotary but I was able to successfully install and zero it. Basically, I just created a recess in the spoilboard to allow the rotary to sit at the height it needs to in order to connect to the QCW.
