Rotary on QCW Frame
Greetings,
Has anyone added a rotary axis to an Elite that’s mounted on a QCW Frame?
Seems this would be a problem with clearance height.
Russ
I’m using a Sherline rotary on a QCW frame. Planning on getting rid of the QCW, but for now I have the rotary table at the back of the machine. No clearance issues, since it’s outside of the spindle travel area. Since it’s mounted in this orientation, I have the Masso controller reversing the A-axis direction.
Thanks Dan.
I was thinking of this, but I think your way is better as rotary sits outside your cutting space.
Mine is still in the idea stage but I may adapt your idea.
I have the 48" x 32" size. Unfortunately, I have to go along the 32” length so I lose 16”.
I bought this:
rotary
Honestly, mine is just thrown together. I bought the small rotary so I could experiment with different rotary CAM software. The rotary is meant to bolt onto the parallel T-tracks on the cast iron table of a Sherline mini mill. I just used the single T-track on the QCW, then shimmed it in place temporarily, which has sort of become more permanent than intended.
If I ever get around to it, I’m going to throw out the QCW and build a stiffer table. I have a 6 inch rotary ready to put together, once I have a table stiff enough to trust to mill the face plate.
Slick idea.
Did the 10mm risers cause any issues? I wouldn’t think so.
So the tailstock must clear with the 10 mm risers?
Get the 10mm risers on Amazon?
I am waiting for my Elite upgrade to ship, and will want to add a rotary as well. I like what you did here with the QCW. Do you have the “attach from above” or Attach from the bottom" trype of QCW? Do you think it makes a difference? My spoilboard connects to the bottom of the QCW and wondering if that will make it a pain to attach a rotary without playing twister under my machine.
I would only choose “Secure from beneath” if you want to do this:
Image: Tilting the entire machine up to access the screws that hold the wasteboard slats
See also
Thanks for the reply. I should have mentioned that my QCW is attached to the rolling, folding stand, I cannot just tilt it up. Looking forward to setting this up.
