Rotary not behaving as expected (solved: forgot to set a axis parameters)
I’m using a simple rounding toolpath from Vectric, but the results are not at all what I’m expecting. It’s as if every degree that is turned on the A axis is 10x what it is supposed to be. I’m using the OneFinity Masso WrapY2A (inch) post-processor. I’ve tried both MM and inch, but no difference. Suggestions?
Ok, I think I figured out what it was…leaving this up for others that might have missed it as well. The A axis configuration on the masso was not correct. After setting the values as shown in the user’s guide, it appears to have fixed it. (Page 26 - https://www.onefinitycnc.com/_files/ugd/6951b9_acf9d10553ee4551b95758064b47bbca.pdf)
