Rotary completing to many turns before X pass
Hey so I think the issue below titled Buildbotics Rotary moves in inches? is very similar to the issue I am having. Can anyone confirm that the settings for Motor 2 Motion section are indeed wrong?
Basically, from what I can see after starting a rounding toolpath from VCarve the revolution is making too many turns. (Video) When it is supposed to adjust a very minimal amount it ends up rotating a dozen times or so. Cannot find any other guidance on the topic. My toolpaths are created in VCarve pro, my A is zeroed, probed from the xyz plate and used the Wrap post processor that onefinity provided here: BB Rotary post processors - Onefinity Rotary 4th Axis 'The Revolution" - Onefinity CNC Forum
#frustrated
Hey, I will say that your quick replies make this alot LESS frustrating! Thank you for that, I’ll try these out!
-Tim
did you get this fixed? I seem to have all of the correct settings but its still just spining and spinging and taking forever
I found another post processor here in the forums that’s for mm and it seemed to have fixed my issues, and cut my carve times by hours.
That does not work on my machine. It just spins and very slowly moves across the project with the bit as high as it can be.
