Rotary Table Issue (aftermarket rotary)
I have updated to Firmware 5.13, and all seems to be running fine. On the stepper motor for the rotary table I changed the dip switches per instructions to 1 and 4 down 2,3,5 and 6 up. Changed the configuration settings for the A-axis per instructions and set inputs 17 and 23 per instructions. Also set the homing so the A axis would home.
This is a non Onefinity rotary that I purchased from Amazon however I have the closed stepper motor from Onefinity installed. This rotary worked prior to me updating the firmware from 5.07 to 5.13. I get a motor alarm on bootup no red lights on any of the motors.
Any help with this would be much appreciated.
Jeff
Did you change the configuration settings as per the rotary manual?
yes changed per the rotary manual. the settings are different than my original settings.
So if you changed the settings and now its not working have you tried reverting your settings to see if your old ones work?
I have not reset the dip switches back to the way they were but will do so today. Originally number one switch was down all others were up. I will also check all of the wiring to make sure all are secure.
Thank you for your help!
Update
Changing the dip switch and the configuration settings back to where I had them prior to updating firmware seems to have fixed the issue that I was having. Although the pendant for jogging seems to be delayed a little for the A axis. Jogging on the Masso works fine.
